Hi all, I've owned a 05" sportivo for about a month now and I've noticed an issue with shifting to second gear when high rpm... It's not crunching nor does it give me any trouble when driving normally although it feels a bit sticky to shift in general.
What is your opinion?
Might it be a clutch problem, gearbox gone or does it need a service?
All original 110xxx km
Thanks all
Clutch needs to be adjusted. Or you can change the OEM clutch to an exert heavy duty clutch and all your problems with shifting will go away.
Thanks guys, appreciate the help
Not an expert but could it also be the Gear stick cable links to the gearbox?
      Remote start
    5. 9
    6. 9
      Turboed Corolla Overbuilt?
    8. 3
    9. 3
