Pics of leaking shocks
gus
driver's side, rear shockiers
details:
+ 2003 stivo
+ 14,500km odo
+ factory springs
+ factory shocks
:angry:
wondered if anyone else encountered shock failure like mine? considering low mileage...
thinking aloud... are stivo shocks of such poor quality? :o
Edited by gus
EEWWWWW thats nooo good bro!!!!!!! Well then im actually not doing too bad then but my shocks are on the way out!!!LOL
Sydney guys will understand this one: *03 conquest.......
*kingSprings super lows.........
*Standard shocks...........
*Taking your car through the nasho run.....
A good way to blow ur shocks!!!! :D :P :lol:
If your rears are leaking that much then your fronts are prolly as bad if not worse. There's a superceeded part number for the rear struts (Jap part no) and the fronts are still the same. Had mine done(all 4) earlier this year.
the other 3 shocks looks ok, but i'm getting toyota to check em out as part of my 20,000km service.
probably get toyota to replace both rears or all 4 shockies if possible :)
what are the jap part no for the rear strut?
what do you pay for quality shocks in australia?
in, w.a. for the stivo, from memory
Koni's - adjustables:
8610-1416Sport (Front) $580
80-2844Sport (Rear) $480
Edited by gus
Anyone have prices for KYB shocks? I am looking at replacing them soon with either Konis or KYBs, can't be bothered with stock shocks.
Btw guys what are the signs and symptoms of worn shocks besides seeing an oil leak? Sometimes its just hard to notice the oil. I know some guys in the past say they hear "knocking" sounds, are they soft, loud, metallic, squeashy or what? I think the only clicking/clunking sound i hear sometimes might come from either the rear swaybar, or front/rear shorter bumpstops, or even the front strutbar. I'm not too fussed abt noises though, its more the driving feel. How can we "feel" for the problem?
Edited by ZEEROLLA
I have investigated KYB options and could only be told that they only do a replacement for the standard strut that's non adjustable and is basically the same. Prices weren't available at this time but may be now.
I can confirm that to, I was told the same.
could confirm if the factory shocks are KYB, when i get mine replaced this week.
Edited by gus
[update]
far out! :o
front shock [toyota part# 48510] $265.00 inc gst
rear shock [toyota part# 48530] $215.50 inc gst
installation $231 (to replace two shocks; x2 to replace all 4)
Edited by gus
[update]
far out! :o
Far out! That is expensive install!!
I had new struts and coils, plus a CES catback exhaust installed for $330!
Regards
Chris
      Drive shafts
    3. 10
      front brake calipers
      Drive shafts
    7. 315
    8. 10
      Dashlight dimmer
