corolla with 86 rims, question
Hi guys,
I'm planning to buy a set of 17/16 inch 86 wheels. Will they fit on 2008 corolla hatch? I'm new here and no idea about wheels. Anything I need to be aware? Someone was saying change wheels will affect actual mileage or something.
Many thanks guys :)
nopp,
86 wheels wont fit, theyre a different stud pattern (5x100) unless you have the new sedans, then no
your stud pattern is 5x114.3 , a 17x8 +35 offset wheel would be ideal for your car,
i heard some guy was selling his bronze work 11r though :g:
nopp,
Thanks jeffy, you saved me $1000, lol. well, gonna do more search then :g:
We will see...wants do more job on my car ^_^
nopp,
yeah i know a guy whos selling 17x8 +35 bronze work 11r with new tyres..
nopp,
I think I'm getting something. :g: lol
  • 8 years later...
On this topic of the Toyota GT86 wheels if you could please assist?  I am planning to purchase second hand Toyota GT86 "2013" wheels to fit on my 2018 Toyota Corolla sedan, but not 100% sure they will fit and if there will be other concerns I need to be aware of?  Spec's as I could gather from both vehicles:
Toyota GT86 "2013"
- 16x6.5 ET48, PCD 5x100, Centre Bore 56.1mm, threat size M12x1.25mm, Tyre size 205/55/R16
Toyota Corolla 2018 Sedan
-6.5J x 16 ET39, PCD 5x100, Centre Bore 54.1mm, threat size M12x1.5mm, Tyre size 205/55/R16
Toyota GT86 "2013"
Not without modification or additional parts - the offset on the 86 wheels is too high and you'll have clearance issues to the brakes.  Also, the 2mm difference in centre bore might cause vibration issues depending on how well the wheel nuts will locate the rim (hub rings can fix this but they'll be thin AF)
    2. 16
      2000 Corolla Ascent - clock.
      ST205 for sale
      Rukus for sale
      CH-R sudden engine failure
      2Door 1975 KE30 Corolla 4Sale
      Hi from Wagga
