Aussie's 2005 Stivo
Aussieakito
Hey guys, just wanted to share my ride
2005 Sportivo Completely stock beside the GT RS rims and Tein springs
10527417_10203178307310790_2058789090686
984173_10203180094075458_881972865850375
I also own a Holden VY SS manual with sunroof red leather all that junk but THIS is my daily :)
Before this i owned a Holden VT supercharged calais
Edited by Aussieakito
  • 9 months later...
Hi guys, been a while since i posted.
Developed a bad rattle from what sounds to be from the exhaust, will chuck it up on the hoist at work and try pin point it. was wondering if there is anything common to look for in regards to the rattle.
Also tinting the fog lights yellow and replacing the headlights this weekend.
Replacing a few worn bushes at the front.
Fixed the rattle, was a broken bracket holding onto the headers, all fixed now.
Fog lights done and bushes done
this was from a jdm meet near me,
11148383_10205147256693294_1006932722438
Which is also when i noticed it had a lot of swirls, so the next day at work i got the detailing department to give it a nice cut and polish
1470310_10205154355110750_80875642978693
And here's one from tonight.
11270510_10205168800751882_5420531289185
The car a mate and i were wrecking had Sony speakers in it, probably not very good but better than stock so ive now obtained them
Will be going in with the old sub and amp from the calais and a new head unit once my fascia kit arrives
Head unit is a jvC KW-AV70BT with inbuilt bluetooth for calls and streaming.
(and yes, something seems wrong with my phone it is taking extra bad photos)
11329932_10205287229152518_1421225741757
11390077_10205287229672531_1762126019497
11391773_10205287230152543_6288319513728
The Fascia kit
Also have the patch leads so i dont have to chop up any of the factory wiring.
Soldered it all up to the head unit wiring, like so.
11350355_10205288441942837_1922623606_n.
In other news ive had to change the LHF Wheel bearing, had it up on the hoist at work and could move the wheel in a bad way.
Thats all fixed up now.
So i was putting the window down last night on a late night kebab run and it only came half way down.
When i went to put the window back up i heard a heartbreaking screech....
The little clips that hold the window to the reg had snapped off.
new clips on their way and re tinting to be done once the clips arrive, in the mean time it looks like this.
11742759_10205660334599921_2771858780256
Ok So the parts i needed to fix the window have arrived.... finally.
These need to me sikraflexed to the window, not sure when i will find time to do these as the window will have to stay out of the car for a couple hours.
Maybe... just maybe ill find time to do it tonight.
These are thicker than the originals so hoping they wont crack.
11220927_10205780627647172_4548999741462
Okay, lots of frustrating updates.
As you know i recieved the new window clamps last night, i then proceeded to try and fit them to the car.
You can see here where the old clip had broken.
11831721_10205786954565341_1724108761452
I spent about 20 minutes trying to free the rest off the clip by cutting the old glue with a blade but this wasnt working so i had to rip the dremel out once again and cut the old one down the middle like so
11200637_10205786955285359_3732825876933
(Groovy shed carpet)
11800032_10205786954445338_6333882946985
11234859_10205786955085354_4966862020538
Once all that was done i spent some time cleaning the window to perfection, then lined up the new clips (without gluing them on just yet)
Fit the window to the regulator and put the window up to make sure all fits well.
In the process bending the regulator and snapping the nylon bush on one of the arms which must of already been on its way out as the regulator hadnt even struggled.
And WHY? you may asked this happened.
Because the new clips are an incorrect fit so when the window goes up they touch another part of the regulator putting strain on the system.
So now i need
-A new glass (with clips attached)
-A new Regulator
-The re tint
luckily as i am in the trade the regulator is only $70, The glass only $95 and the retint $40.
The Regulator is already in my possession and the glass is on its way.
lesson: The cheap way usually becomes the expensive way :doh:
DONE!!!!
So i finally got the window fixed, although it wasnt without more failure.
As i went to put in the new reglulator i realised that i have recieved the wrong one........ yes.......... gotta love wrong parts :censored::upyours::bang::ranting:
BUT alas i was able to use a part from the new reg to fix the old one, i then put the new window glass in, tested it 1000 times before and while driving to tint-a-car.
long story short.. its fixed
11850535_512240578925053_366706560325892
As you can see i had to jack the car up to change the window :rofl2:
11850747_512240575591720_186273927435394
My clutch started slipping so i decided to change it..
1 driveshaft is split and needs to be reconditioned, the other. welllllllllllll..... It didnt want to come out and i uh... broke it
So yes 2 reconditioned drive shafts to come.
The cup of the driveshaft is still stuck on the box, going to attempt to get it off once the box is out as ill have a lot more room.
Everything was going so smoothly until that moment :bang:
Have some pictures
11986935_10205953795496260_4509114269494
11954749_10205953795576262_2632196521375
11986576_10205953795856269_3550092549430
11902308_10205953795936271_3321709820787
11846794_10205953796296280_7697981246776
11919110_10205953796456284_7476314572079
11947480_10205953796416283_4804894760395
EDIT: oh and yes i bought the clutch, and the tools... ended up going with a Clutch Industry Heavy Duty clutch, also bought all the bearings to go along with it.
11951979_10205952355940272_4653375073341
Up bright and early to finish this job.
10329050_10205958478493332_3755692103529
Box out.
11214348_10205958478173324_7605002533019
The thrust bearing is actually crusty and hard to turn, lucky i got to it in time. It started putting some nice big grooves in the pressure plate springs.
11988754_10205958478253326_1369130514432
11960063_10205958479293352_7268494286730
I was able to get the remainder of the drive shaft out once the gearbox was out.
so it was time to head off to M & S driveshafts to get them reconditioned.
11951222_10205958478573334_1950363545717
(Shout out to my misses for letting me borrow her astra for the week :spot on: )
11209516_10205958479613360_1799169449632
11949349_10205958479853366_2828135084361
11953191_10205958480133373_7985594044713
Fully reconditioned drive shafts
11990642_10205958480813390_5153690510560
Good old Toyotas, dry rear main unlike every single holden ever created.
11987143_10205958479533358_1548170760249
last job is to get the flywheel machined so off to Brakeswest Sunshine to get that sorted, and here it is.
11947538_10205958480533383_6107940416514
Oh and of course it just wouldnt be right if the clutch actually fit. nope still never received the correct part first go for this car.
So now im waiting for the correct clutch to be to get delivered hopefully with in the next hour.
Well last night i had put most of the car back together: Flywheel, clutch, gearbox, driveshafts are all back in all that was left was to change the oil in the gearbox, fit the slave, bleed the system, fit the airbox and battery.
I got as far as trying to put the slave in and guess what, i managed to strip the thread on the line...
So this is how she looked this morning
11960081_10205964670968140_6169191450632
All mounts in and bolted up
11947405_10205964671048142_2383377192377
11949420_10205964671288148_7988781694020
Sadly though it was time for work.
10570455_10205964671368150_3060991108917
10646667_10205964700808886_8487532012674
NOW, i can get started fixing that thread for the clutch line.
11924966_10205964671688158_8610296135117
11924224_10205964672008166_4244270657492
10848033_10205964671968165_2399716387246
Now.. all fixed :D
The heavy duty clutch feels much better and grips a lot more :D
      Any RA 60 owners?
      Bluetooth stopped working
    5. 3
    6. 2
      Toyota Corolla Sportivo
