Hi all, new here and was wondering if someone might be able to help with an odd problem that just started tonight?
I have a TRD Aurion that will not turn off the accessories (radio & dash clock) which is stopping the remotes from working!
It is a smart key system and all functions are not working as it thinks the car is in ACC mode.
I'm still able to start and drive the car but when I turn it off as mentioned the radio & dash clock stay on.
When I open the door the buzzer goes off and when I walk away the car still thinks the ACC are on and flashes/beeps "KEY NOT DETECTED"
I have to disconnect the battery so it won't drain it.
If anyone has come across this or has any suggestions I would be appreciated.
Did you shut the car off whilst it was still in gear? Did you try pressing the start button again?
It was in park when I turned it off and the start button just runs through as normal.
1st accessories, second accessories then starts and drives.
Just when I turn it off again, 1st accessories stay on ( radio/dash clock) which won't allow the remotes to work or even button on either front doors.
It sounds like the ignition is staying on, does the car restart from that point?
    2. 0
    3. 9
      Android auto
    4. 9
      Android auto
    5. 1
      Turboed Corolla Overbuilt?
    6. 3
    7. 3
    9. 18
