Timing chain rattle on startup
dba
Hi Everyone, new member.
I drive a 2007 Kluger Grande and for some time have had a momentary rattle on start up. Recently I split an oil hose and since having it fixed the rattle has gotten louder. It only lasts a second or two and then stops. If the engine is warm, there is no rattle. I have been told it could be the timing chain tension, the lifters, or the timing chain guides. All of those sound expensive. Has anyone else had a similar problem?
Thanks Trent, have been doing the research as you suggest and found a suggestion of increasing revs to 2000rpm before turning off engine. Will try it for a while to see how that goes.
Before i left Toyota, the cost was around $450 per gear (you need 2) and i think it was around 12 hours labour. Yes, engine out to reach the rear vvti gear.
  • 5 years later...
      Stout Owners
    2. 12
      300 series turbo issues
    3. 8
    4. 55
      Stout Owners
    5. 2
      New Member
    7. 199
      Current Oil Specials
      Advice Please
      Fortuners Transmission
