Corolla Power FC Help.
i making power fc harness for my corolla runx...he sent a diagram to me... but i have conection problem for one pin its between power fc,stock ecu ... so i want ask him to solve it
I have noticed that there were two terminals going to the same E7.12 pin. Which one is the real one? Or both signal going into E7.12?
E pins are normally grounds, no? If that's the case then having two pins going to a ocmmon ground point is not an issue
*Disclaimer - Even though I understand it fairly well I hate auto electrics with a passion, thus any advice in regards to such should be taken with a massive chunk of salt. Something iceberg-y in size would be appropriate
      Stout Owners
    2. 12
      300 series turbo issues
    3. 8
    4. 55
      Stout Owners
    5. 2
      New Member
    7. 199
      Current Oil Specials
      Advice Please
      Fortuners Transmission
