theres an oil leak somewhere behind the engine and i can not see where its coming from , any ideas it keeps running off onto my cat and pisses smoke everywhere , but its not losing much oil tbh its just i need to find it for rwc
didnt even no it had em hahaha
SXV20 Camry 5SFE heads have 3 blanking plugs to fill in the ends of the camshaft line-bores - 2 "half-moon" plugs on the ends of the head in line with the exhaust camshaft, and one full blanking cap on the passenger-end of the head inline with the intake camshaft (where the distributor fits on the SXV10/Celica 5SFEs). They are all common leaking points if they aren't re-sealed properly when the cam cover gasket is changed.
Had another look seems it could very well be the o-ring on the dizzy lol typical i shouldve replaced it when i did the internal dizzy shaft seal and bearing -_-
I just realised, you have one of the last SDV10 or SXV10 models.
yup build date of 04/1997 :)
right before the switch
The SXV20 models deleted the distributor as Hiro said. It is a common place for them to eventually leak regardless of year.
well its running from where the dizzy meets the head so it looks like that dam o-ring but figures i shouldve done it when i did the dizzy shaft seal
Distributor seals leaking is classic '80s/'90s Toyota...
agreed 100% LOL those daM DIZZY SEALS ALMOST EVERYTIME
lol so far 2k spent on this peice of #### and its coming close to getting a duckin match and a petrol soaked rag i put a new thermostat in it and its god dam faulty, i swear i am going to lose it with this car soon and burn it to the ground after ive taken it out bush and stomped it till it dies
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
