1997 5S-FE CAMRY OIL LEAK
975s-fe
theres an oil leak somewhere behind the engine and i can not see where its coming from , any ideas it keeps running off onto my cat and pisses smoke everywhere , but its not losing much oil tbh its just i need to find it for rwc
didnt even no it had em hahaha
SXV20 Camry 5SFE heads have 3 blanking plugs to fill in the ends of the camshaft line-bores - 2 "half-moon" plugs on the ends of the head in line with the exhaust camshaft, and one full blanking cap on the passenger-end of the head inline with the intake camshaft (where the distributor fits on the SXV10/Celica 5SFEs). They are all common leaking points if they aren't re-sealed properly when the cam cover gasket is changed.
Had another look seems it could very well be the o-ring on the dizzy lol typical i shouldve replaced it when i did the internal dizzy shaft seal and bearing -_-
lol so far 2k spent on this peice of #### and its coming close to getting a duckin match and a petrol soaked rag i put a new thermostat in it and its god dam faulty, i swear i am going to lose it with this car soon and burn it to the ground after ive taken it out bush and stomped it till it dies
    2. 54
      Stout Owners
      New Member
    5. 199
      Current Oil Specials
      Advice Please
      Fortuners Transmission
    8. 199
    9. 1
      Advice Please
