Iv sused out which wire to cut a switch into to disable traction control/ vcs in a caldina gt4 st246 if anyone needs any info its a very easy mod to do just imposible to find out any info on it
  • 4 years later...
I did this a few years back. You need to find the steering angle sensor and fit a normally closed push button in one of the wires. When you start the car and hold the button down for a few seconds the ecu sees it as a fault and disables vsc (you get warning light) until you turn the car off and back on again.
Someone else might be able to confirm or tell you what colour the wires are.
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
