Aurion cigarette lighters
Viper001
Hi all
First post here.
I have a 2012 Aurion which has 2 cigarette lighter outlets. One in the front panel and one in the console.
I only use them for charging USB items.
Suddenly, yesterday, they both stopped working. I have checked each fuse in the fuse box and they are all OK. (Although I could not find one marked "cigar" or anything like that)
Any suggestions?
Many thanks
Craig
There is a specific 20-amp fuse for the cigarette lighter sockets labelled 'CIG'. This is located inside the car under the glovebox. You'll need to poke your head underneath the dashboard and pop out the black plastic trim that covers the fusebox, but it will be the 26th fuse (bottom row, 3rd in from the right). The diagram on top of the fusebox will help if you get stuck. If that looks ok then pop up your centre console (5-second job) and make sure the wiring connectors are plugged in nice and tight.
Edited by Full-Throttle
There's another 20-amp fuse right next to the 'CIG' fuse which is labelled 'PWR OUTLET'. It's the second fuse in from the right on the bottom row. This is the one for the power outlet/socket in the centre console.
      help with clutch
    2. 3
      newbie from Queensland
      High mileage camry
      1981 Hiace ignition upgrade
      Aftermarket Air Intake
      Heater problems
      Entertainment Unit Upgrade
