Coilovers
HIROLA
  • Replies 62
  • Created
  • Last Reply
Top Posters In This Topic
i would never have another car without them, and i know of at lease 4 others on the forums running cusco's that would say the same thing.
amen to that brother :D :D :D :D :D
ive never lowered my car with jst springs so i cant really compare coilovers to anything else..
however the appeal of being able to choose a height and dampening is quite a positive.
u will never get the same ride quality as stock.. but ur handling and driving experience/fun will definately increase!
*two thumbs up*
i was the 1st to get cusco zero2..
for daily use, makes interior rattles after a while..
keep that in mind but other than that for handling wise
cant get better :)
other than the coilies, also need to get good tyres to help them
or else still be going under.. my 2cent :)
cant get better :)
Yes true about the rattles already started hearing them but u knw wat .... its a corolla its built to rattle
<_< <_< <_<
And yes i gave the tyres an almighty test .... just imagine 80km of natio run type roads but the difference being the road is smooth and flat unlike the natio :D :D :D :D :D :D
My verdict ...... I LOVE MY SETUP :D :D :D :D :D
So given the generally harsher ride with coilovers. Would users recommend a 16" or 17" wheel/tyre package to suit?
if you go 16's you will have better tyre selection AD07's etc appart from that i dont think the ride would vary alot between the 16 and 17's
depends what u want..
looks or warrior set up?
lol
warrior my opnion should stick with superlight 16"..
and for tyres best bang i reckon the rt215.. performs very well on streets..
and they dont wear as fast as other semis :)
if u want street ill stick with ad07 or bridgestone so3
What spring rate did u get with the Zero 2?
7kg front and 5kg rear are the standard springs rates on zero2 for corolla's
unless u request other rates on ur order :)
from my experience the zero2 spring set up on the dc2r are a little better..
they have 8kg front and 6kg rear..
no, on the track 17s are NERVOUS on the limit with 215/40r17. 16s are faster around the track as well.
i know pippy will tell u the same.
agree!!
rt215 are no longer available they have been replaced with rt615 which have a design more suited to cornering then the 215s
oh really..
well there u go..
u find out how much they are?
Hey guys r coilovers easy to install??? can i do it at home my self??
Well, with the right tools and know how, yes you can. Danz did it at home with a couple of people to help him.
But you'll then have to get your wheels aligned at a shop anyway after that.
    6. 21
    7. 21
    8. 21
