Hi everyone,
My '04 sportivo has a slow-ish leak, it seems like its below or near the PCV valve but I wanted to get your opinion on what it is and how to fix it. I have about 195,000 kms on it, and need to do an oil change anyway so figured I may as well fix this beforehand. An image album is linked here
The last image is probably the most helpful, by my guess. A key thing to note is that I dont really know what I'm looking at, like names of stuff. I've done a rocker cover gasket replacement in an SR20 with the help of a friend, and will probably get his help again but hoping to get a head start on what the issue is.
thanks!
Give it a good clean as well. It looks filthy, which does not help tracing the source of the leak.
As best I can see it appears to be the hose or maybe the valve cover gasket, but I can't put any certainty on that.
Add wider shot pics for better referencing.
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
