Changing P/S hose SV21
Our SV21 has been loosing power steering, mechanic tells me it will be $300 approx to fix. I have moderate diy skills, anyone comment on the degree of difficulty of this job as I'd like to have a go at it?
I've changed the topic to reference the fact that we're talking about a power steering hose, most people will think of the radiator when you say "upper hose"
  • 4 weeks later...
you can do it from the top, only real pain is having room to swing the spanner. i did it a few months back because i refuse to pay a mechanic so much money to do a job that i can do myself. it's an easy job itself and so straight forward but, as i said man, the room to swing that damn spanner. from memory i believe it's a 19mm, 22mm and 24mm i think that you needed. that's for the fastner at the top on the firewall and the ***** bolt on the pump. if you were in queensland i'd help.
      maps in 2017 Camry Altise
    3. 5
    4. 4
      Front Cameras
    6. 51
    7. 51
      1kzte throttle body
      Aftermarket parking sensor
