Hi guys
Just wonder in if the above wheel 215 60 16 with 36pos offset will fit standard suspension/ride fit my 2000 Camry 4 cylinder
Even if the wheel size did fit, I would be hesitant about going to a wider tyre for your model Camry.
I fitted 205/65/15 to my 1998 4 cylinder Camry. All was quite OK in the dry until I had to hit the brakes hard at 80kph on wet highway and aquaplaned [despite having good tyres]. Fortunately the vehicle starting to illegally pull out of the right hand turning lane stopped. Not a nice feeling knowing that an accident would have written off my vehicle.
Suggest you have a read of the URLs for your further consideration.
https://msawheels.com/wheel-offset-explained/
http://csadirect.com.au/fitment-guide.asp?DataBankId=184&DataBankCat2Name=Toyota&DataBankCat2Id=19&T=0
https://summitracing.custhelp.com/app/answers/detail/a_id/4638/~/hub-centric-rings
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
