NEED HELP(NO Cabin air filter)
Marco Tam
Hi everyone, I am Marco, I owned 2004 toyota camry sportivo MVC36
Recently, when I turned on my A/C, the air is so smelly.
so I checked online and look some article in the Toyota club.
I recognise that 36 series didn't have any cabin air filter.
Thus, what should I change if I want to stop the stink.
Although, I am not expert and I am a student, the engine air filter will help it or the other ways  can improve the situation?
I hope someone can answer me. Thanks
Have a lovely day guys
Marco
You can actually install a cabin filter in the ACV36R series, if you cut out the opening where the cabin filter should be installed there is space for it. I went to my local wreckers to try this before doing it on my own car and this it how it looks like . The cutout isn't perfect as I was using a bad knife. The RAV4 and also maybe the Tarago cabin filter tray should slide right in perfectly into the slot if the cutout is done right.
  • 3 years later...
Hey mate what is the number of the rav4 filter that you have managed to fit in the AV36 toyota camry as the replacement cabin filter
I used the RYCO RCA140MS
Thanks for the quick reply ZRCamry04..
Does the outside cover come with the RCA14OMS or did you make one?
Edited by Vivek
incorrect question
Do you mean the tray?, The tray I got from the wreckers from a 2005 Rav 4
  • 4 months later...
Above where the tray is there a open gaps, see above photo. Wouldn’t a piece of filter over this work rather than cutting out plastic. Any build up that still gets into fan is very easy to remove, three screws drop fan and clean.
  • 9 months later...
Hi, I bought, in Thailand, the same camry and was very surprised to not find any cabin filter.
So what have you done finally?
What Hi, I bought, in Thailand, the same camry and was very surprised to not find any cabin filter.
So what have you done finally? cut?
What number of filter did you use if you used one ?
      Aftermarket Air Intake
      Heater problems
      Entertainment Unit Upgrade
      Seat change
      1993 Corolla Seca CSI limited
      Corolla Seca For Sale
      High mileage camry
