I have just had my 3rd original ignition coil fail on my 2008 corolla and was wondering if its normal for coils to only last 120000klm.
That's not a horrible lifespan. Some last longer than others. It's very hard to quantify how long they will last.
  • 6 months later...
Just noticed an eBay seller saying that the recpmmended replacement of ignition coil for a Toyota was 10 years or 100,000 miles [160,000 kms].
In October, I replaced an original coil on a 2007 Yaris with about 190,000 kms on the odometer after it threw up a check engine light. Spark plugs also ended up being very worn and well overdue for replacement which was done. I am thinking that if the spark plugs had been replaced earlier then there would have been less demand/stress on the ignition coils.
This weekend, I have replaced the spark plugs and all of the ignition coils on my Toyota Aurion which has done 204,750kms. Previous owner would have had the spark plugs replaced probably at 100,000kms and it is most likely that the DENSO ignition coils were originals.
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
