Bluetooth failing to connect
Hi! I have a 2013 Corolla ascent sport, with a 100182 multimedia system. I purchased the car second hand from a dealer in the ACT and had it delivered to me in northern NSW. long story short it's a brilliant car I'm very happy with it, the only issue is when I go to connect a phone it automatically says connection failed, doesn't give me the chance to even look for the device. I tried initialising it again and also disconnecting the battery but neither of these did anything. Im busy at the moment and work long hours so don't have the time to go to the Toyota dealer in my town to have them look, I was wondering if anyone had the same issue or knows how to fix it
Hi Larkey99,
I'm having the same issue with my 2015 Corolla. The SD card is PZQ60-00552. It says "Connection Failed" immediately after trying to add a device. I've tried the same troubleshooting and haven't been able to resolve it either.
Please update me if you find a solution.
  • 1 year later...
Same problem here.
Bluetooth of my Camry 2015 worked well before. Now it says bluetooth module is not connected.
Remove personal information is not working, trying to update the firmware or reset it, but don't know how to do this.
      Drive shafts
    3. 10
      front brake calipers
      Drive shafts
    7. 315
    8. 10
      Dashlight dimmer
