Posted (edited)
Hi,  I have a 2008 Toyota Camry and it’s showing an error code P0136. This starts showing the warning lights after I switch over petrol from other brands. I was normally using bp premium. is there any issue if we drive with these warning lights .
Can anyone please tell me the best place to repair for this issue.I am from North Melbourne. How much will it cost?
Thanks for guiding.
Jude
Edited by Jude M
Adding place
This should not cause the error code. It's just a coincidence that it happened to happen around the same time you decided to change fuel.
Have a read of this as it fully explains the situation and give you an idea what you are dealing with.
https://www.engine-codes.com/p0136_2008_toyota_camry.html
It may very well be a coincidence but I would start by removing and cleaning that O2 sensor.
      Tow bar
    2. 3
    3. 0
    4. 3
    5. 3
    6. 3
    7. 1
      Snapping wheel and axle studs
    9. 2
