1ZZ Runs comparison CAI vs No CAI
Hi Guys,
I recently aquired a Gtech Pro RR. It accuratly tells you things we really want to knwo about our cars LoL See picture below.
Myself and Dave (YDOIT4) have given the thing a go at an unnamed independent strip during our lunch breaks. Below you can see some minor differences
The Black Line is Dave's car : Stivo exhaust - Quick SHifter - CAI
The red line is my car : Stivo exhaust
You can clearly see the points where the CAI makes the most difference. What i have to say id dave did have both of us in the car and it was only me for my run so you can add that as well.
This is HP vs Time
This is G force Vs Time
This is HP and Torque Figures on the right
All i can say is cant wait to get my CAI fitted. :P
We will do some better testing with dave next week.
It plus into your ciggerette lighter and detects RPM via the altinator.
This looking at RPM and Speed agaist Force as it sucks onto the window and detects the G force. You enter your vechele weight and redline and off you go.
http://www.gtechpro.com/test.html
check out these linkshttp://www.soloperformance.com/ShoppingCar...ormance%20Meter
almost 103kw with a stivo exhaust and cai? <_< are u for real? :huh: *apologies if i read the graph wrong - I WANNA STIVO EXHAUST!! :D
Edited by RME1
Well the strip was downhill so the actual figures are out. THis was more for comparison and its not even anyway. We also need to ge tthe exact weight of the cars with the people in them before the actual HP and TQ figures will be accurate.
Once we get this i will post some with a even road. ALl this is used for is comparison :)
1070kg's is a corolla (1zz) - the age says :)
u should compare with a stock 1zz - how does the stivo exhaust compare? more high end gains rather tahn low end gains?
Keep up the good work! look forward for more results :D
Yeah will do.
THe problem is the Gtech needs a gross weight including yourself and feul
Those weights on the websites are kerb mass which does not include this
we will og to the local tip and get a weight as is soon then we have accurate results.
      Advice Please
      Fortuners Transmission
    3. 198
      Current Oil Specials
      Advice Please
      A Greenskin
      Car Detailing Recommendations
      Landcruiser 200 GPS
    8. 11
      300 series turbo issues
      Any 2L motors for sale?
    10. 1
