2012 LC200, Want to rebuild the engine
forumoto
I have this 1VDF diesel, v8, 2012 model. I want to change the piston rings because there is excessive blow by gas in the crank case..
I have tried to look for a good piston rings which will fit the engine but Toyota has only STD , OverSize ring, I write to find out from members here if someone can recommend a good piston ring that is oversize and has resistance to wearing ..
please message me here. Thanks
      2Door 1975 KE30 Corolla 4Sale
      Hi from Wagga
    4. 12
    8. 3
      1VD - Ticking Noise
    9. 3
    10. 5
