Good afternoon,
I have a 2016 GUN126R with 150,000 kms on the clock.  Always serviced on schedule. Stock except for oil catchcan, fuel prefilter and 2" lift, although with bullbar and side rails and winch, it's more like a 1" lift.
I am heading for a trip to the Simpson Desert soon.  I would like to know peoples opinions on what parts I should consider replacing.
I am thinking water pump, wheel bearing and UJ's
I carry a spare CV, although never needed it.
Any thoughts will be greatly appreciated.
Andrew
Id ***** of the catch can
Hi Bigpete, I have only heard good things about a catch can.  What is it about them that you don't like?  thanks
With EGR the oil  helps trap all the abrasive matter entering the intake the black crap in your intake , i believe its better to have to clean it out when needed , better with a blank plate and forget the black crap if only anything it acts as an upper cyl lubricant , ive got a plate 160k no rubbish at all in the intake
