Posted (edited)
Hi All,
New to the forum, I'm after some help regarding a ticking noise coming from my 200 series;
I picked up the car from an auction, noticed a slight ticking noise when the car started, and gets louder as the revs are increased
I went through the service manual and used tech stream. - the injector values were fine.
Then I did a cylinder shutdown test - I noticed the ticking reduced considerably when I shut off #8, however the ticking was still slightly there
I went ahead and changed #8 injector - when I started the car the ticking was still there, if not even a little louder than before.
Any suggestions as to what it may be will be of great help
Some info of the car
2010 - 200 Series
4.5TD - 1VD
340k kms
Thanks!
Edited by jaggaj
Sounds to me like you have an issue in your valve train. You mentioned that you purchased it from an auction. I suspect it's had a hard life and may have missed an oil change or two and it possibly ran low on oil pressure and did some irreversible damage.
I'd take it to a qualified technician and have them inspect the timing chain and valve train. It may be fixable.
Did you find out what the noise was. Mine is doing the same.
  • 3 months later...
Posted (edited)
Cracked Rocker..Its been known to happen. Inspect the Roller Rocker arms. This Valve Train has a roller rocker Hyd. lash adjusters..If it ticks then it's either a cracked rocker arm or less likely a buggered seal in the lash adjuster
Edited by Buzz66
    2. 0
    3. 9
      Android auto
    4. 9
      Android auto
    5. 1
      Turboed Corolla Overbuilt?
    6. 3
    7. 3
    9. 18
