2002 Corolla Levin Hatch Cup Holders - ZZE122R
The cup holder is between the seats, you need the dividers that slide into the slots, my car has 3 dividers. https://www.google.com/search?q=2003+corolla+cup+holder+divider&client=firefox-b-d&sca_esv=6efbeb0f0e2294b8&udm=2&biw=1112&bih=587&sxsrf=ADLYWIJt_XZzGgUeqXXpqk2rntdvKavBZw%3A1723430917872&ei=BXi5ZpX2NJjg0-kP4vCegQY&ved=0ahUKEwjVjJ69uO6HAxUY8DQHHWK4J2AQ4dUDCBA&oq=2003+corolla+cup+holder+divider&gs_lp=Egxnd3Mtd2l6LXNlcnAiHzIwMDMgY29yb2xsYSBjdXAgaG9sZGVyIGRpdmlkZXJI8zZQrhpYrhpwAXgAkAEAmAGWA6ABlgOqAQM0LTG4AQzIAQD4AQGYAgCgAgCYAwCIBgGSBwCgBy0&sclient=gws-wiz-serp -
hey guys, what are you guys doing for cup holders in these model corollas? is there some sort of factory option that this model dosent have that can be added? any ideas are appreciated as there isn’t any cup holders whatsoever in it currently. have attached some photos for reference, cheers -
13
Where are my rear speaker wires terminated?
Hey guys I went to install new rear speakers but I don’t have any speakers there or wiring so I’m wondering what to do if there is wiring where would it be -
Electronic Hydraulic Handbrake
Just wondering if anyone else has this noise when applying or dis-engaging handbrake. Has had the "Toyota fix" done, but still makes noise after short period of time. Have complained to Toyota Customer Services, but have been told it is within specification -
Toyota seca 1998 , program new fob
Hi , The original fob for my 1998 toyota Seca is dying. I have purchased a new genuine Toyota Fob. Can anyone help me program the new fob. Thanks Best Regards Jodie -
40
FUEL WARNING MESSAGE
Thanks Geoff, great stuff. I’ll just keep going until I get home in a couple of weeks. I will be in a much better environment (my shed, with concrete and hoist, etc, etc) when I get home. I’m not going to look at it while knee deep in dust, 🤣😂. Once I have worked out what the problem is then I will let you know. by the way, it seems that you can buy just the new pump itself without having to buy the whole assembly. I’ve done a few in tank pumps before with petrol driven cars and I’ve found a you tube on it for the LC200. but I will be looking at the electrical side of things first. -
40
Thanks Geoff, great stuff. I’ll just keep going until I get home in a couple of weeks. I will be in a much better environment (my shed, with concrete and hoist, etc, etc) when I get home. I’m not going to look at it while knee deep in dust, 🤣😂. Once I have worked out what the problem is then I will let you know. by the way, it seems that you can buy just the new pump itself without having to buy the whole assembly. I’ve done a few in tank pumps before with petrol driven cars and I’ve found a you tube on it for the LC200. -
44
Upgrading 2010 Aurion ATX Headlights
Update, went for my first drive at night.... Wow 😳 what an improvement!!! Why didn't I do this earlier?!! Didn't get flashed, so I assume it's not too bad. At least these were designed to work with projector lights. I could see leds being an issue when used with reflector lenses- 2
Help - Blowing white smoke
Search on this Forum or do a Google Search with the search term of white smoke on startup or similar. It is definitely NOT valve stem seals for the Toyota 2GR_FE engine. The white smoke is due to oil vapors being drawn into the intake manifold. The PCV valve needs to be cleaned/replaced as a starting point. You can also try to desludge the engine and an oil change using a quality known brand synthetic oil and a new filter cartridge. Most likely there is significant oil sludge build up in the front valve cover. A definite proven solution is that the cover needs to be removed and thoroughly cleaned. Also go back to the proven old school approach of regular oil change intervals of 5000 kms/6 months. -
6
