What the He11 are these?
SyxXPaC
You have to use the springs supplied as the spring retainers are machined to fit the springs in the kit. They are a kit that you simply weld the sleeve over your standard strut with the thread on it and use the top mount and there you have a coilover of sorts where you can easily adjust the height but not dampener etc unless you use Koni sports struts.
Be careful as welding struts can make the oil inside heat up and also can affect the operation of the valving etc with the intense heat. Not something to attempt at home!!(unless your Rollamods ;) :P )
A bit off topic but kind of relevant.
What has more weight?
A conventional seperate coil and strut suspension set up, or the equivalent coilovers?
Hm...I'd say the coilovers would weigh much less. My D2's aren't in yet so I just picked one up in my room with two fingers around the coil. That's lighter than the existing suspension housing i'd say?
definately conventional is heavier as it is real steel. i remember playing around with the early d2 models about 2 years ago and they were lighter since constructed with different materials alas some was not true steel and easily broke apart
      1989 Hilux Low Voltage
      Ae92 genuine low ks 70800
      Code P004B
      Upgrade from 2012 to 2023
    9. 3
      Towbars
    10. 5
