I want more aggressive 3rd 4th 5th and 6th gear in my Current setup,
anyone know anthing about gears?
I don't
I heard i can change the actual cogs.
you would have to swap the entire 2zz tranny and engine rather than just the engine. they do physically bolt together, but the output shaft sits at a different position than the 1zz.
I am sure either TRD, C-One, TOMs or Spirits manufacture close-ratio gears for the 5 & 6 speed gearboxes. They usually chnage the 3rd, 4th and 5th gears in the 6 speed and keep the final drive ratio. An LSD is also a common addition. Will cost a bomb though to get them from Japan and you would need a specialised mechanic to work on the gearbox.
I have a BM vid of a TOMs MRS Turbo (190ps) with the 1ZZFE and it had the stock 5 speed gearbox, and it was tearing up the touge.
i want the MR-S with the 2zz! :P
there was one touge vid where they really loved the handling and drive of the c-one celica but everyone bitched about the ride-height!
Hmms i will go ask about these gear ratios.
A LSD? I know a LSD transfers the power equally to both wheels.
but does it help with the gear ratios?
No, it has no effect on gear ratios but probably reduces the amount of power loss through wheel spin during hard cornering which would be what you want with that much supercharged torque :P
    2. 1
      Tyre Sale Specials
    3. 0
      overheated engine
    4. 1
    5. 62
    6. 1
    7. 1
    8. 1
      Tyre Sale Specials
    9. 10
      Android auto
    10. 0
