single sub or duel set up
bassposse
lmao... oh yeaaaa forgot about the amp... but then again bassposse was just asking about the sub... i'm HOPING :g: that he has a good amp lol
ofcourse a system is only as good as its weakest link... remember that son :D
oh and don't forget... tune tune tune... tune it yourself because what an installer thinks sounds good may sound like cr4p to u... we all have different tastes
you can get get 2 channel mono block amps... kinda confusing but there designed to be bridged as a single channel. but i doubt thats what this is as there not that common and not that cheep
anyway an amp means two fiths of **** all most the time. for day to day listning you probly wouldnt know the difference between a mediocor amp and a hi end amp.
soon as you start the car any improvement go's out the window.
if you want to compete in SQ comps then sure, get the best you can.
MR and MSROLA - what store does MRROLA work at?
i have spent 10 years and $30,000 on car audio. it wasnt till 2 years ago i started to be able to hear little differences and subtles in the music and the charicteristics of speakers and amps.
you will hear more difference from a better quality sub than you will a better quality amp
Well he did ask for a sub, so I did not question his amp. Fuddbutter is also right on how more of difference can be heard with a better speaker then a better amp.
With regards to my comments to how corners and flat panels are not good for enclosures, I wasn't 100% sure on that. But it was quoted out of a Hi-Fi magazine, with egg like speakers going for about 5000 UK Pound.
I hope this thread does not go astray...
smaller speakers you can get standing waves, midrange speakers suffer from it alot.
and them egg and round speaker enclosuers look porno!
ok to try and clear thing up about the amp
this is what i found on the net about the amp...
The V12 AccuClass-D amps deliver massive amounts of power for driving subwoofers as hard as you want to. Theyre the only amps on the market with a true digital design. This keeps the signal purer and makes them extremely efficient. Another big benefit is that they use digital signal processing to provide time correction and other sophisticated controlsall controlled through the Alpine Digital Control Center located under the top mounted access panel. If your system requires more than one of these awesome amplifiers. Alpine also has an Amplifier Link unit that lets you connect as many as eight of these powerhouses and control them from the head unit.
it is ONE channel not two ...my bad
Product details
General
Product Type Amplifier
Recommended Use Car
Width 13.7 in
Depth 10.6 in
Height 2.6 in
Weight 8.8 lbs
Audio System
Equalizer Yes
Response Bandwidth 20 - 200 Hz
Signal-To-Noise Ratio 60 dBA
Max Output Power / Channel Qty 175 Watts x 1
Amplifier Output 1-channel
Input Signal Voltage 0.1 - 8V
Crossover Active crossover
Crossover Slope 24 dB/octave
Phase Selector Yes
Low Pass Frequencies 30 - 200 Hz
Amplifier Output Details 350 Watt - 2 Ohm - THD 1.0% - 14.4V DC - 1 channel(s)
250 Watt - 2 Ohm - THD 1.0% - 12V DC - 1 channel(s)
150 Watt - 4 Ohm - THD 1.0% - 12V DC - 1 channel(s)
175 Watt - 4 Ohm - THD 1.0% - 14.4V DC - 1 channel(s)
Built-in Display LED
Additional Features Input level controls, subsonic filter, time alignment
Equalizer
Equalizer Type Parametric
Equalizer Boost/Cut Range ± 12 dB
Display
Type None.
Connections
Connector Type 1 x audio line-in ( RCA phono x 2 )
1 x audio line-out ( RCA phono x 2 )
Speakers output ( screw-type )
System components control bus
DC power input ( screw-type )
i think this is correct not 100% sure
i dont know 2 much bout amps all i was told when i got it was thats its a alpine mono block 760W amp and thats all i know bout it
here is a picture of the box it came in
Edited by bassposse
      2000 Corolla Ascent - clock.
      ST205 for sale
      Rukus for sale
    5. 8
      CH-R sudden engine failure
      2Door 1975 KE30 Corolla 4Sale
      Hi from Wagga
    9. 12
