Hey guys I just picked up my 03 Sportivo on wednesday and lets just say :clap:
The other day i started up and went out hard and it cut out at round 7000rpm only did this for 5mins or so but :blink: can anyone let me in on why???
secondly is there any way i can get the central locking to beep wen i lock and unlock???
Posted (edited)
Ack! You mean to say you just started the car then put your foot down ?? :blink:
There was a previous thread on this...basically the sportivo needs to be warmed up before the ECU allows the engine to engage lift. Without warming the engine up and revving the snot out of it is not healthy for the engine at all (any car you care about, should be warmed up before driving it spiritedly).
Perhaps someone else can help you on the beep for your cenral locking though (no idea here :P ).
Congrats on getting a nice car!!!
Edited by Delvance
gday mate, welcome to the club.
as delvance said, u need to warm up the car before u try and hit lift.
as for the central locking, u'd prob need to get an alarm for the car as the stivo only comes with an immobiliser as standard.
congrats on the purchase
Yep make sure you warm up the engine before you try hitting the high cams. The MIVEC, VVTLI and VTEC systems all have this safety feature built in, to prevent premature engine wear.
As for the beeping sound when you lock/unlock, late 90's Toyotas had an option where you could toggle the settings between silent or horn alert, ie: when you hit the button it beeps in time with the indicator flash. It sounded pretty poor though just having the horn go off randomly :blink:. Use "Search" and look for "Toyota Alarm Upgrade" and see what people have said about the factory option, I'm not sure if it has a cool noise alert or not. Other than that you'll have to go aftermarket
Basically NO.
The factory remote door locking ECU has no outputs for the horn unlike the dealer fitted remote locking.
The only way would be to make a custom electronic circuit and use the aftermarket plug.
Or buy a dealer fit unit. Note the dealer fit unit uses a fob and your on key lock/unlock buttons would be useless.
Factory fit key
http://cgi.ebay.com.au/Toyota-Prado-Key-Cu...1QQcmdZViewItem
      Snapping wheel and axle studs
    2. 0
    3. 2
    4. 0
      2003 ln167 hilux 5le engine oil leak
    5. 2
    6. 0
      Steering wheels to fit 2005 Hilux Single Cab 2wd Ute
    7. 7
      Android auto
      Squeaking rear door
    9. 1
      New Member
