Ggn15r Transmission dip stick
Hi, just wondering if I have the AT filler, drain and dipstick labelled correct. Adding an inline temp gauge to coolant line and want to swap the fluid out as well. 1st time without a normal dip stick. 2006 GGN15R 5 SPEED AUTO 120,000km Hot coolant line is on the near side. Thanks -
Torque settings for 2014 Toyota RAV4 transmission pan bolts
Hi all, Going to do a drain and fill on the wife's 2014 Toyota RAV4 transmission on Sunday and was wondering if anybody has the talk settings for the transmission pan bolts please? The sump plug would be great if you have that too please! Thank you in advance -
How to reset CV36 single button key fob
Hi all Upgraded my CV20 to a CV36 (woohoo!) as a run around vehicle. Only had one fob, so got a couple of matching single button fobs online on eBay. However having an issue with programming more than one of them at a time. I know how to do program them no worries. But when I do, only a single fob stores in memory at a time, such that if you go to program a further fob, the prior fob gets lost to memory, and the newest programmed one takes over. Looked everywhere, regarding resetting the memory for all fobs for the vehicle, thinking the memory may be full, but all instructions are related to USA 2 button models, not the single button fobs we use here. Nor can the remote seller help. So, wondered if anyone may have an idea how to reset the receiver in the single button fobs, for the 2002-2006 Camry ACV36's Appreciate any advice -
Fortuner off-road & touring equipment sale
Selling; > matt black bush barriers $500 > custom made false floor with fridge slide professionally made at Lawsons Drawers Adelaide $500 > Kaon rear shelf $150 > Black Duck 4 Elements seat covers, driver, passenger, 2nd row seats. $1,100 new. $700 new condition. All in new near condition taken off my 2022 Fortuner when I sold it over a year ago. photos and videos can be sent -
Coolant leaking from radiator?
Hi Herb, Yeah, I had a look under the car and saw a big puddle of fluid about the size of a large Domino's pizza. I crawled underneath to see what I could see and saw fluid dripping from my bash plate so I traced the dried/stained fluid up the side of the bash plate to the bottom of the radiator. I had a good look at the radiator and saw what I took in the picture I posted earlier. I had a good look at all the hoses and pipes and couldn't see any cracks at all. Same with the caps for the fluid tanks. Cheers, Alex -
Hi Alex, Are you absolutely sure that it is leaking, like have you seen coolant anywhere? The 1995 Hi Ace, I bought< went through coolant all the time, I was forever topping it up. For some dumb reason, I had a good look at the radiator cap, and found that the rubber seal was as stiff as a board. A new cap solved the losing coolant issue. Herb -
4
