Idle issue?
Hi all,
I've noticed since I've owned my "05 stivo that it has had some problem I believe with the idle,
Everytime I shift it feels like the idle completely drops for a split second and then jumps up again, a mate with a rolla at work reckons he has the same problem? Is this normal or is there something wrong with the sensor or something?
Any help will be appreciated
Cleaning the ISCV (same thing as IACV) does make all the difference in the world. I had the same sort of problem and it was resolved with cleaning of this valve.
Mine ended up being faulty and had to replace it but the clean did make it better for a period of time.
would this be the same problem?
when my foots on the acceleration and I decide to change gear (granny shifting) after im in gear I press on the acceleration and it seems to lag abit around 2.5/3 rpm.but after 3000 rpm it pushes normally and the car doesn't feel like its chocking.
Edited by GHOSTIVO
Sounds a bit similar, although it only for a split second, makes you wonder is its normal or not?
Where is the iacv located?
      Stout Owners
    2. 2
      Lost Yellow guiding lines on reversing camera screen
    3. 0
      New Member
    4. 199
      Current Oil Specials
    5. 1
      Advice Please
    6. 0
      Fortuners Transmission
    7. 199
    8. 1
      Advice Please
      A Greenskin
