Electrical Issues maybe??
Ok folks, attempted to install an electrical device, things went horribly wrong.
My ABS light is on constantly, Handbrake light on constantly and Speedometer isnt working. I've tried another stock ecu and the symptoms are the same so its not hte ECU. I've checked teh fuses in my fuse box in the engine bay as well as another one under the passenger side of the dash board, they are all good.
Any ideas??? Help!!!!!!!! Thanks..
try taking it to toyota.. dont mention the "electrical device"
things happen alittle differently where I am from. The dealer is not your best friend, especially when there is 1 Toyota dealership and you didnt buy your rolla from them or anyone on the island, lol.
The easiest answer is an Auto Electrician, but I wanted to hear soem thoughts before i booked times.
what did you try to install and what wiring did you touch?
If the ABS light is on you will most likely have to get a fault code cleared from the ABS ECU with a scan tool, if the parking brake light is on, check the wire from the park brake switch near the handle back to the body loom.
      Current Oil Specials
      Advice Please
      Fortuners Transmission
    4. 199
      Advice Please
      A Greenskin
      Car Detailing Recommendations
      Landcruiser 200 GPS
    9. 11
      300 series turbo issues
