painted engine cover
pujo
what did you paint it with?spray paint?did you spray primer on it beforehand?if u didnt, that might be the case.
yeah i used spray paint and i did put primer on it. 2 coats of it.
Edited by pujo
looks like you sprayed it too thick
yeah, you're right. i think i got abit excited. sprayed the 2nd coat (even this time) and it looks much better
just waiting for it to dry so i can apply the final coat
nice!thats better ^_^ good luck
Looks good! but did you do a bit of light sanding before you laid down the base coat (primer)?
what bout clear coat? you gonna be doing that too?
Edited by JJCRU23R
thanks guys, yeah i did abit of sanding. i didn't put any clear coat coz i was too excited to bung it in me engine... :D
That looks like it has fried up due to the cover having traces of silicone on it(armourall etc etc). Be sure to rinse the cover with thinners or wax and grease remover before you paint.
Secondly use plastic primer as it has a sort of elasticity in it to allow flex with out cracking the painted surface. I use 2 coats of this then apply 2-3 coats of colour followed by 2-3 coats of clear. Allow ample time in between coats for drying before applying the next coat. If you do this then you will have greats results.
These are the methods I use and my results pretty much speak for themselves.
  • 5 months later...
  • 4 weeks later...
    6. 21
    7. 21
    8. 21
    10. 3
