Newest addition to the blue bombshell
xoom
as i had indicated in the brakes section i was looking at an upgrade and so i went with the rotora big brake kit.
they just arrived today
now to see if they fit under 16's as it states they should ........
ok if the pics dont load (stupid image site) the direct links are
You shouldn't have any fittment issues Bill as long as the TuRD wheels aren't a strange design. Pippy's 16" Enkei's fitted over the 302mm setup we did for him, so your 295mm should be fine :)
The only issue (if you can even call it an issue) was getting the wheel balancing weights changed from the ones they stick to the inside of the rim to the type that clip onto the lip of the rim. But with 295mm you may still clear them anyway.
Edited by MAP81
      Aftermarket Air Intake
      Heater problems
      Entertainment Unit Upgrade
      Seat change
      1993 Corolla Seca CSI limited
      Corolla Seca For Sale
      High mileage camry
    10. 4
