Lag in Rev Range
Got a little problem with my Stivo
after installing my sri
i noticed a little lag in the rev range between 4500 - 5500 rpms
it was fine when i had the stock box but after installing the sri it started happening
does this happen to any1 with a cai or sri?
should i reset the ecu or is it the sri?
cheers Denz
cheers Denz
didn't you take out the battery to remove the stock airbox? coz if you had the battery out for more than a few mins, it would have reset it. Just drive it the car around for a little while to see if the ECU adjusts.
cheers Denz
oh btw, does it happen when the engine is cold or only when it's warm?
