How do you remove water marks?
2009 Kluger white smoke
I know there are plenty of posts in regards to my header but... I have removed the rocker cover and cleaned it out, replaced the pcv, removed the plenum and cleaned it out (new spark plugs was the reason for removing fhe plenum), fitted a catch can between the pcv and plenum, new oil filter and oil... but I'm still blowing white smoke on start up and after about 20 minutes of driving and getting pinging (usually hear that and then the smoke comes). If I pull over and let the smoke finish I can drive fine as long as I stay under 2000rpm (or go up a hill too steep). Since I have fitted the catch can I have driven to and from work and on average have about 150ish mls of oil in there. Now I know the smoke on start up is oil sitting in the intake but that should be caught in the catch can.. Any help will be greatly appreciated . -
stop start camry
Did you mean to write: "Not coming up" instead of "Coming up"? If you meant what you wrote, what reason have they come up with? Also, you failed to state the model and engine type of your Camry. All relevant details are necessary for anyone to reply in a meaningful way. Whatever the model, has someone run the codes? OBD1 or OBD2 etc. Jim. -
New Member
Hi everyone, just thought I would say thanks for letting me join. I pick up our 1st used 2016 Kluger Grande with 53K on the Odometer in a weeks time. I have researched as much as possible as I'm not a Toyota guru and would appreciate any nice to knows OR things to be aware of regarding mechanical maintenance. I believe these motors have a timing belt that should be replaced at 100K??? Anyway I look forward to navigating the forums on this site. Thanks again.. Safe Travels SteveinTamwort 👍 -
08 200 series winch
How do u fit a winch with the genuine bull bar. I'm assuming there is a mounting bracket available. 08 200 series. -
27
Head unit sd card issue
Signed up to say thank you. Had a similar problem on my car. Battery died so called someone to replace it. Found that the audio system does not work anymore. STEPS for newbies/non-tech people: 1) Get SD card if you don't have one. Probably from Kmart: SanDisk Ultra MicroSD with MicroSDHC and MicroSDXC Adapter SQUA4 - 32GB - Kmart 2) Downloaded the four files linked by nzkicks 3) Format your SD to FAT32 format and then copy the files across to the SD card 4) Take it to your car. 5) Turn on the engine of your car. Wait for the audio system to say "Program required to load the system" or something like that 6) Insert the SD card 7) It should then ask you for security code. For me, it was last 5 digits of my VIN number. and then it works 😄 -
AE102 Corolla suddenly stopped and now won't start. HELP PLS
Thanks for your reply Hiro, I will give it another go -
1965 Toyota Lite Stout Ute
Hi all I’m a new member living in Melbourne. I want to pitches a lite stout Ute. my father gave me one ( second hand $750 ) when I was 18 and I loved it until my brother wrote it off getting stuck between a tram and a garbage truck. Now in my 70s I want to purchase one -
6
Replacing 1999 Hiace fuel pump
Hi Curtis1995 I am in the process of dropping the fuel tank on my 2000 HiAce van to replace the pump. It appears you've managed to remove all 3 of the hoses to/from the pump/tank. I have managed to disconnect the 2 with simple squeeze clips but am having no joy in disconnecting the final one. I have attempted to loosen it using ring spanners with no joy. Do you have a special technique with this or am I taking the wrong approach? I have read that some connection require special tools. I hope this isn't the case for this. Next on the agenda will be the filter. Not looking forward to that either. 😮 Cheers -
Key FOB registered but remote not working
Hi, I got a third-party key fob online and registered it to my RAV4 2018. The process was fully successful but the new key works like the original key without a battery. I changed the new remote battery, but nothing changed. 1. Remote button (Both lock and unlock) not responding. I used the computer diagnose function to check the remote, it came back as "remote not registered". The remote was sending "locking and unlocking" signal correctly. 2. Key less entry function not working. When holding the key and opening the front door, the door won't unlock. 3. Push start won't work. The car can't detect the key. I have to hold the key against the start button to turn on the car. Basically, the newly paired remote is same as the original remote without the battery. Can someone please help me with that.
