Corolla Lowering Springs
Hey guys I'm new here. Got a 2007 toyota corolla, recently just got a set of lowering springs. Does anyone have a DIY on how to install them. Anything from a 2003 corolla and up is the same setup, so if you got anything let me know :D I got the general idea on it but would rather something to go by.
not too hard, just need the right tools
a breaker bar helps heaps
unless you want to die, then yes get a spring compressor,
you'll also need it to get the hats on properly for the fronts, unless your going super low
bonbon-2zzge you do know the ZRE152 is different from the ZZE 122/3??
Fronts may be similiar but the back is totally different. ZRE152 doesn't have struts on the rear but has a shock that is independant of the spring.
xpyyy that's looking nice. Hopefully I'll be able to lower mine soon, it's been sitting 4WD heights for like 8 months since getting 18" lol
off road stivo! Nice....
Haha well it's stock heights, but with 18" rims on it, EVERYONE has told me and I already know it, "Man that's like a 4WD, get it lowered already."
I will soon :yahoo:
Well i got lowering springs put on, sits about 2" off the ground =) looks good ill take some more pics.. also i have a turbo comin in august.. my question is i have a stock motor all i got is a cold air intake... what is recommended to upgrade in the engine before doing the turbo? =) Thanks for the help fellas!
Forged pistons for starters or your engine will melt before your very eyes ............
im a bit stupid, how or where do i get forged pistons? and anything else ill need?
The guys here might be able to enlighten you ............ Kenneth especially ~!!! :D
As for anything else you need ............. Errmmmm .....
      Invisible Instruments fix
      Can I use USB hub to get more USP ports?
      Rav4 smart key keyless entry
    9. 13
      Starter motor issues
