factory 6 stacker
Ascent = single CD headunit, Conquest and upwards = 6 disc in-dash headunit with bluetooth. To the OP, there is no separate 6 stacker option whatsoever.
Yes and if it is like the unit in the is200/300 lex it will be nothing but trouble .......
whats wrong with the is200?
Intergrated front consoles require buying a new front console piece in order to fit your headunit. Whereas the Corolla consoles have a double din (slighty larger actually) hole which your headunit can slot in nicely.
stacker is in the headunit? i believe the ascent is a single cd headunit, does toyota mean that a 6 stacker as a dealer option is replacing the single with a 6 stacker headunit?
That's correct. You won't need to worry about any wiring harnesses if you go down that path.
The stock unit jams a lot ,,, iv found that if you only put 5 disks in its stops jamming and works fine :blink: ...
      Seat change
      1993 Corolla Seca CSI limited
      Corolla Seca For Sale
    5. 4
      2013 camry for sale
      Rav4 smart key keyless entry
