Adding a sub to my stereo...
emememinem
Hey people...
I have a 2004 camry sportivo and want to add a subwoofer to my stereo, i have the amp, and i have the sub... but when i went into alberts they asked me all these questions about the back of my head unit... like does it have rca out-puts and other questions that i kinda had no idea of... does anyone know if the stock head unit is capable of attaching an amp and sub to it, and if so is there anything i need to know before i go to someone and get it installed??
Thanks Heaps!!
hey mate i just went through putting a sub in myself into my rolla :P
ive been told (this is most likely incorrect but someone can correct me) that stock toyota HU rarely have rca cables (the rca carry the signal for the sub from the HU to the amp in your case) and even then it's best to put in an aftermarket HU. A few more things to note are your power cables, grounding cables , speaker cables and dont forget the fuses! Make sure that whatever guage cable you get for the power to run from the battery to the amp has an inline fuse as close to the battery as doable so in the event it blows you dont have a live current running through your car. Also the grounding cable (attach to the metal body of the car) should be of the same guage as the power cable or interesting things happen :spiteful: , it's also a good idea that you dont just bolt the grounding cable to the next bolt but actually drill a new hole and scratch the buggery out of the paint for a good contact :)
What sort of amp, sub and sub enclosure you got mate? :)
Goodluck
I really doubt your stock head unit would have rca plugs but you could always flip through your owners manual and see if there's any info on it.
Better yet just ring a Toyota service department and ask em.
Goodluck
Hey cheers heaps for that ay... very much appreciated... might have to invest on a decent head unit aswell... at the moment ive got a boxed 12" pioneer... buying the amp probably within a couple of weeks after ive done a bit of study on it :) only thing about getting a head unit is that i wont be able to use the stearing wheel controls on it... "sniff"... but im sure ill live... and im pretty sure with some head units you can wire them up to work with the steering controls anyways yeh? Thanks heaps for your reply ay much appreciated!!! and yer if i get it all wired up i definately wont do it myself, wouldnt trust myself at all... :P thanks again!!
yer head unit didnt say anything about rca plugs either... so yep, think im gonna have to start saving up for a head unit :) thanks!!
If your buying a new HU my suggestion is dont be cheap! Just putting in good quality head unit to replace my stock unit i've had my audio sounding better then alot of my mates. The best bit is i spent a few hundred on my system... most of them spent $1500+... Rolla ftw! :D What wattage is that Sub btw? Be careful with what amp you get as well :) if you can try to stick to main stream brands unless someone can vouch for you that it'll work well :)
Pretty sure some people have managed to hook up the steering controls? is yours wired or IR?
haha putting in a new HU, Sub and Amp isnt that hard, all you need is the basic tools, plenty of spare time, someone to supply cuppa's and a handy diagram with the Toyota Wiring Diagrams :clap:
BUT!!!
Always disconect the - Terminal on your battery first as well....
Doing it the way leon did can will only work for very very small, non power hungry subs, Anything else you'll fry the outputs from the headunit.
you can get this line signal convertor thingy from pre much any audio place ( i got mine at autobarn)
its basically a cross over that takes your speaker signal and filers out the treble or bass
it has 2 swtiches that let you set high and low cut offs
you hook it up to your existing speaker lines
and it outputs the filtered signal to rcas
you hook the rest up as per norm, cept
for the remote, use the acc power line to the headunit
i used this on my stock head unit in my corolla
edit: the unit is like 20 bucks
Edited by bonbon
^ yep i did that too! was awesome, but i always had some lag on my amp when i turned on my car, my amp didnt come on until a few seconds during the song.
how did you go? what you do? where yo from? maybe i can help? lol
Hey :P im all the way over in perth... well havent done anything... yet... still lookin for an amp... im confused on whether to just split the speaker cables with that device... or get a new head unit... getting a new head unit will be more of a mess around... but maybe worth it... im still doin some study on amps too... i have a 400w 12" sub (800w max) 4 ohm... i have no idea what dual voice coil is... can someone explain it? and what do i need to match up to buy an amp... the impedance or the wattage? or both... and is the whole dual voice coil shiznit important... ???
Sorry to hijack the thread...
But are you meaning I can buy these lil devices and attach them to each speaker, and filter out the bass in the speakers?? My HU hasn't got a High Pass Filter and I have my rears runnin off the HU lol... would come in handy!!
QUOTE (bonbon @ Jul 12 2008, 08:50 PM)
:lol: I taotally agree with this idea~ <_< the serive is expensive in some shops.
      Seat change
      1993 Corolla Seca CSI limited
      Corolla Seca For Sale
    5. 4
      2013 camry for sale
      Rav4 smart key keyless entry
