Hey everyone,
i wanted to ask if it is safe to have 98 octane fuel in a standard 02' corolla??
just want to be sure that the engine wont have problems
Evo
Hey everyone,
Evo
No problems whatsoever. The car should have a knock sensor, so it'll automatically adjust the timing to suit the higher octane/slower burn. Generally, running higher octane in a modern car is never a problem, the main problem is running LOWER octane than the engine is designed for (ie running 91 or 95 in an STi Impreza or 4AGZE)
Thats all i run in my 03 Ascent... i tend to get more kays out of a tank. I have only owned the car for about 3 months and havent had any problems car if anything runs smoother on 98 ron.
Sure is safe, id say even better for the car. I tend to try and stick to Shell, followed by BP. It's personel preference though, but from what I have read and heard it seems to be the goer.
i use 100 octane 5% ethanol in my car best fuel around from shell runs like a charm on highway i get almost 1000km out of a tank
no problems mate, i too have an 02 corolla ascent, and i run on ether 95 RON or 98RON.. just because it's ment to be a cleaner fuel.
I use Shall V Power for my 08 Corolla, and thinking about using the 5% ethanol or 10% ethanol, does anyone know are the ethanol any good? or should I stick with the V Power?
Check out http://www.toyota.com.au/parts-and-service/maintenance
Toyota state that all Corolla's built from July 1994 can use Petrol/10% Ethanol blend.
I worked in a refinery belonging to a major oil company for many years and have seen what goes into the various octane petrol blends.
The minimum octane petrol that I will use in any of my cars, is 95 octane!!! Nuff said!
    2. 0
    3. 9
      Android auto
    4. 9
      Android auto
    5. 1
      Turboed Corolla Overbuilt?
    6. 3
    7. 3
    9. 18
