Squealing noise when AIRCON is ON
layzie
That funny noise that squels when the A/C is on is the belt and it needs to be adjusted as it's too loose. If it's been doing it for a while then it may now need to be replaced.
If you hear a noise that doesn't sound right investigate it or take it to you mechanic. the longer you leave it the more expensive it could become.
      Head Unit with Apple CarPlay
      Any RA 60 owners?
      Bluetooth stopped working
    6. 3
    7. 2
