Fuel tank capacity
I have a 2004 ascent sports rolla hatch. now according to the manual the rolla has a 50litre tank. try as i might the most i have ever filled is about 40 litres. Is this just me or is the same for the rest you guys.
ascent sedan 2003 manual says 55 litres but the
most i have pumped in is 40-45 litres
the light to indicate to refuel goes on very early and you can drive around a lot still.
hey... i drive a 2004 corolla levin. it says 55litres in the manual book and it starts over-filling when i reach around 40litres on the petrol pump?
probably because we already have 5-10litres already left in the tank itself.
yeh that happens to me too, i guess its just a saftely issue that toyota chucked in, by having 10 - 15 L left when the yellow light turns on, it usually stops people driving it to empty coz they realise they haveta fill up, driving to empty isn't very good for your injectors let alone your engine.
Melvin
      Drive shafts
    3. 10
      front brake calipers
      Drive shafts
    7. 315
    8. 10
      Dashlight dimmer
