TWM Short Shifter
Correct me if i'm wrong but i think...
The heavier gear knob is meant to reduce the effort required to change gears.
Using a short shifter, actually means that you increase the effort required to change gears by simple physics.
1. Lowering the shifter by 2.5", means that you'll have less leverage
2. Increasing the fulcrum point height to reduce the shift movement, also means less leverage
Therefore the heavier gear knob in principle is to offset this increase in effort.
This is pretty much spot on. The heavy gear knob acts as a counterweight when shifting.
I think a lighter gear knob gives your better 'feel' whereas a weighted knob numbs the shifting abit. But I think with our boxes a weighted shifter works far better.
Hi Kenji,
I was wondering it you happen to have the part number for both the twm short shifter kit and the gear knob. Im interested in ordering this exact combo too.
Also, do you have any photos to show the new height with the new short shifter in?
Steve
It is the 2003-2008 Corolla on the twmperformance website. The gear knob is the satin big type R with pattern 3 engraved.
You can pick any of the shifter knobs as with the ntis tech they all fit. Height can be adjusted to whatever height you want
with their ntis gear knobs. But if you still require a picture I can take one tomorrow and post it up
Would it be possible to install a short shifter in the 08 ZRE? I've had a thought about it and it seems like a massive headache, ripping the panels around it and being set up so high wouldn't make installation easy.
Not sure if the ZRE is the same as the american 08+ corolla. You'd have to check with twm if their Short shifter would fit.
With most japanese cars, it is usually quite easy to take apart the centre console and dash instruments and popping out the
shifter wouldn't be too hard. If the twm short shifter were to fit, then instructions would be included.
Kenji
I highly doubt it. American version is a 5 speed, ours is a 6 speed.
Your best bet is actually emailing them to find out.
the same trd quick shifter can be installed on 1zz (5 spd) and 2zz (6 spd)
Yes, but from my experience a few things between the ZRE in America/Asia is not compatible with the Australian version.
Moreover,
Hello,
Thank you for your interest in TWM Performance products. The 2009 (north
american) Corolla is available in both 5 and 6 speed (XRS) versions. We
have tested our short shifter on the 5 speed and we have had customers
installing it in the 6 speed as well since the shifter assembly is the
same for both cars.
We did not have any Australian customers testing this product yet. If you
are able to remove the stock shift knob, shift boot and center console (as
described in the installation manual available on our site) and take
pictures of the shifter and shifter assembly, we could take a look at it
and confirm if it's the same as the north american version. If you are
interesting in doing so, we could also offer you a discount on the short
shifter.
However, please note that if the Australian 6 speed 2009 Corolla is
equipped with a reverse lockout mechanism (if there is a lever to pull up
or if you have to push down on the shifter to get in reverse), our short
shifter will not fit.
Thanks,
Frank
TWM Performance
This ends the query of whether or not it fits.
      Gen 6 Cluster Backlighting Issues
      Hilux surf
    3. 6
      Buying a Hilux / Surf
      05 hiace ecu
      1989 Hilux Low Voltage
    6. 27
      FUEL WARNING MESSAGE
    7. 27
    8. 27
      Wanting to build my car.
      2004 hzj79 surging/jolting
