Sticking on TRD badge help
Hey guys,
I have a TRD badge and I want to stick it onto my rolla but need some help and ideas on how I could stick it on.
This is the back of it. Just double sided tape
This is where I want to stick it
Help?
Cable tie :lol:
Obviously as you have noticed and now that you are asking, that spot is not going to be easy to mount to unless you do a bit of custom work. If I was that desperate to stick it there, I would remove all the double sided tape from the back and stick two pieces of metal tab to the badge so they come out perpendicular to the badge. Then you would stick these tabs to that black part of the inner grill thing. Hard to explain, but the end result will look similar to those air fresheners you clip to your air vent, only one side of the clip is missing.
That gave me idea. I just took the clip thingy off my air freshener (Some type s racing thing) and what do you know. It clips onto the front grill perfectly. Just need to get another one of these and glue it onto the back of the badge
My 06 "rolla has it's TRD exactly where you want to put it...run a thin line of clear silicone slightly above and below the contact point, and also a thicker line where the actual contact point will be .
Remove the double sided tape, and carefully position the badge. There is just enough room to slide your finger behind the badge to smooth out the silicone, dont drive and leave it overnight to toughen off....works a treat !
That mod alone added 10hp to the beast... :P
nicely done ;)
I wonder how much extra hp i've added to my car. I mean i've got another +20 hp for the red painted engine cover, +5 hp from the red door sills, oh and +5 hp from the red coloured CAI
Looks alright mate.
Abit hard to see me thinks.
You could have maybe put it here:
But still good :)
      1kzte throttle body
    4. 3
    5. 5
    6. 5
    7. 8
      PZQ60-00525 Issue
    10. 3
      Head Unit with Apple CarPlay
