1995 Camry Coupe
Engine Oil leak
Hi all, I'm new to the forum and hoping the brains trust here may be able to help, maybe even seen the issue before. I have a 2010 Hilux KUN26 193k on the clock. I have been searching for a possible cause of a clunk which has developed which sounds and feels like backlash. It seems to be coming from towards the front of the vehicle. While the vehicle is idling along in lets say first gear and if I was to ever so slightly touch the accelerator pedal I get a clunk sound like something is engaging and then let my foot off again it happens again but like its disengaging it can felt through the car. I have had it up on a hoist and checked all the engine and gearbox mounts which all seem fine. The tailshaft and uni joints all seem fine also. The clunk happens in all gears but once cruising in any gear you wouldnt think there was an issue. Originally I was leaning towards a clutch issue but only because I was noticing it while changing gears but with further investigation I have noticed it happens without touching the the clutch pedal and just on and off accelerator. I have a throttle controller on the vehicle and thought this may be the issue so I unplugged it and nothing changed. Im hoping someone has seen this before and can point me in the right direction. -
project 2007 camry grande
The wreckers don't want to sell the centre caps , they only want to sell complete wheel sets. Toyota dealers can supply them new in a packet , but don't know if there is one in a packet or four. -
300 series HiAce van
I have a 2023 swl HiAce van. Has anyone else had trouble with the paint. I have rust coming through on different location on my roof -
Hey Mate, Im no professional so dont quote me on this, but I think that's normal. They flash when you break traction and the DAC kicks in. If it's constantly flashing at you even when you're not breaking traction, you might have a problem. But it's the same thing with traction control on newer cars. It flashes at you when the traction control is activated and you are sliding or drifting, or whatever. -
4
I'm having the exact same issue as Graham. Last time they told me it was the battery. Toyota still can't find the issue, going in for service in about 2 weeks. We'll see what they come up with this time.
