Cheap BLING
peregrine
(1) Chrome Grill:- 12mm pin striping on each of the cross bars. Top of tape just above top lip of bar, run the tape along the bar, cut to size and curl excess under bar. takes a little bit of patients but its easy. If you do a lot of country running subject to stone chips you might like to try covering the job with a few coats of clear lacquer but if so don't forget to undercoat the bars first with an appropriate plastic undercoat.
(2)Grande chrome emblem on rear doors, just above side protector garnish about 2 inches from the back of the rear door. Looks classy.
Edited by peregrine
most effective way to upload pics would be to use a file hosting site such as photobucket or imageshack.
if using photobucket copy paste the 'img' link into the thread (it will appear as words) when you press add reply the image will appear no need for us to click on a link. photobucket is free you just need to register.
Thanks yes it worked.
      2Door 1975 KE30 Corolla 4Sale
      Hi from Wagga
    4. 12
    8. 3
      1VD - Ticking Noise
    9. 3
    10. 5
