New Headunit and Speakers without Amp?
macaroni
Hey guys,
I've got the stock headunit and speakers in my car right now and I'm thinking of replacing them with a set of basic Pioneer speakers and headunit. I'm just wondering if I'll need an amplifier as well? And usually how much does installation cost?
Hi. as long as your new headunit got MOSFET build-in amp, there is no problems to run the speakers by the headunit.
If you dont install amp, the installation labour would be quite simple, (take old headunit out, connect harness, put new one in, take old speakers out, put new one in)
I would say 1hr to 1.5 hr labour would be sufficient.
Maybe you can DIY it. not as difficult as you think.
Ok guys, I got the headunit installed but the speakers are too big to fit in the existing speaker hole. The Celica spakers are on the dash area, next to the glovebox and steering column, so I can't even cut it to make it fit. Is there another way to fit them?
      Drive shafts
    3. 10
      front brake calipers
      Drive shafts
    7. 315
    8. 10
      Dashlight dimmer
