1ZZ Turbo on Ebay
Lawz
In Theory:
i would buy this car and put the turbo kit onto my car ;)
twin-charged 1zz FTW!
BTW: i wouldn't really :P (but a twin-charged 1zz would be alot of fun ;))
Evo
does anyone know approx. how much a setup like this would cost?????
It says: MODIFIED WITH A BALL BEARING GARRET TURBO, FRONT MOUNT INTER-COOLER, EMS COMPUTER, BLOW OFF VALVE,2 EXTRA INJECTORS, TURBO BACK EXHAUST,FRONT MOUNT OIL COOLER.
Doesnt seem to metion anything about heavier duty internals......Does this mean you can run a turbo without touching the internals???????
Of course you can turbo a 1zz with stock internals... Pippy's daily driven levin has been running forced induction for the last few years, and been turbocharged for the past 12 months: http://au.toyotaownersclub.com/forums/inde...showtopic=18153
As for costs to do the same to your car, like the ebay one...
BALL BEARING GARRET TURBO & custom Steampipe manifold - $2K
FRONT MOUNT INTER-COOLER & Cooler pipework - $700
EMS COMPUTER, install and tuning - 1800 (EMS Stinger can't do closed-loop vvti control, so would need to be piggybacked to the factory ECU)
BLOW OFF VALVE - $50 for a Bosch, $200 for a Ricer version
2 EXTRA INJECTORS - $160
TURBO BACK EXHAUST - $1100
FRONT MOUNT OIL COOLER $300
Then there's a lot of little stuff like the fittings for the watercooling of the turbo, turbo oil feed line and return to sump, heatshields, etc etc etc.
I'd personally not bother with 2 extra injectors and just run some appropriately sized main injectors with the aftermarket ECU. Twincharging is a massive waste of time too, turbocharging alone with a properly matched turbo achieves much better results.
Edited by CHA54
Couldn't have said it better myself, if you can do the work yourself and know where to look you can shave a couple of hundred off that.
im sure ive seen and heard this car driving around the hills area
well im sure u need to get your car back on the road bill
because ive neither seen or heard from the car in 6 months
if u want to pay somebody to do it properly u are looking at a min of 10 grand easily
Fixed, but explain properly though? For a complete forged engine, decent ECU, custom plenum, etc you could be looking at well over $10k.
For those of us with limited budgets it can be done for a lot cheaper.
Ie. Manifold - $600
T28 - $400
Exhaust - $1000
Adaptronic - ~$2000 fitted and installed
2nd hand cooler + piping - $400
Assorted bits and pieces - $400
There you go, less than $5k if you can do the work yourself.
      1993 Corolla Seca CSI limited
    3. 15
    4. 2
      Navigation absent ? From apps 2016 atx model aurion
      Landcruiser Prado (150 series) AVS suspension
    6. 2
      93 Landcruiser Trip Meter
    9. 2
