300hp corolla on youtube
Camry Hybrid. 4.2L/100km to 7.6L/100km
Picked up a new SL in late Feb 2025. Currently 2,500km. Fuel consumption has gradually decreased from around 6 down to now around 4.9 with city and occasional country drives and I expect it will get better. The drivetrain eCVT works flawlessly with instant pickup. Overall, so far, it has surpassed my expectations! (having had company Camrys in the past). I'd changed from a 2017 CX5 Touring that averaged 9.5 to 10 in city driving. -
Engine Oil leak
It is most likely either the oil cooler line or the VVTi oil pressure line. Only the engine oil cooler line is covered by Toyota's extended warranty. -
Sad day
Have a read of the following thread which includes my post back in March 2022. Toyota Australia provides an extended warranty for this issue when this oil cooler line leaks. Phone Toyota Australia Customer Service 1800 869 682 who will ask for the VIN and maybe also the vehicle registration. They will give you a warranty claim number and details of the local dealership. Next step will be to contact that dealership for a repair booking and quote the warranty claim number. Your Aurion is not driveable and towing will be arranged by the dealership. Your outlay will be $0.00 -
2022/23 Grande Cargo Barrier
We have recently purchased a 2022 built 2023 model Grande and want to out a cargo barrier in. Toyota say that it can not be sold as the barrier only fit the gxl due to the panoramic sunroof (not truly panoramic as only half retracts). Anyhow, is it possible to put install the cargo barrier or is there an after market option available? -
Sad day
Hi all just signed up, I have a Toyota 2011 Orion, yep the dreaded oil cooler lines, a hose blew, I had pulled up to a 99degree turn all was well , then 30 mtr up the road sounded like a truck was next to me then noticed it was my car rattling it’s ***** off, being not even 10mtr from my drive way I idled it into the drive way and oil was everywhere, i placed oil in the car as it read empty on the oil stick , had my partner start the car and wow it was pumping strait out of the hose it had a hole in it ,I turned it off strait away, and researched it, so disappointed I have owned Toyotas all my life and owned this pride and joy for allmost 3years iam second owner with around 212000 on the clock, I am replacing it with the upgraded lines but am know afraid it’s done some serious damage, as idle sounds fine but not game to give it a rev till it’s all fixed, I don’t understand, it states if leaking to return to Toyota, I had no leaks the hose blew a hole, the recall also says extended warranty and has no date or km, for the oil hoses , Am I say up **** creek with out a paddle ?? I will check log books to see when last serviced from Toyota and when recall was made. ?????? -
Engine Oil leak
Hi Helen1234 I went the cheap option also from Ebay for my 2010 Hilux. It took multiple attempts to get mine to work but after the 4th or 5th time it did exactly what was supposed to happen. The instructions need to be followed perfectly and if you dont the fob will not learn the system. I was personally having the issue where the car thought I took the key out of the ignition because the key barrel is worn. I had to take my key off my key ring because the weight from my house key, canopy key and bottle opener where weighing down on the key when it was in the key barrel. Good luck, hope you get it to work
