Engine Immobiliser
18
5
Tow bar
Snapping wheel and axle studs
Put a set of standard wheels on it and your problem will disappear. It is critical that the hole in the wheel centre is a snug fit on the axle boss (without wheel nuts fitted). If your wheels are sloppy on the axle boss this allows excess force on your wheel studs and they will break, as yours are doing. If you are unsure of what to do, go to a reputable tyre shop and get assistance.
