Fly Audio GPS DVD Install
Hado
What is incredible with these units is that none appear to be able to do bluetooth phonebook (for making calls via name, displaying name and number of incoming calls etc).
When even $200-300 portable gps units have this features it is a serious oversight in such expensive units.
Anyway guess see what the future holds:)
I'm pretty usre this unit supports downloading and displaying of your phone's phonebook, happy to be proven wrong by others (plugnplay?)
Have a look at the link here it shows the features:
http://www.flyaudio.us/7500-series/53-for-...ander-e7548navi
Hi ,
yes this has been made available for the overseas market but we in Australia will receive in April next Month
Regards
George
Can you shed any light on other new features that may be of interest?
Will this update cause a new model number that we should all look out for?
Price difference over the existing model?
  • Replies 80
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Hi ,
Regards
George
This is the only upgrade that I have been made aware of
The price will be provided on release next week or so we do not know as yet
Well I am happy to be proven wrong then:)
Big thing I guess will it supports iphone 3gs phonebook, as this seems to be a tricky one.
Keep us updated plugnplay. I have heard rumours that it will allow phonebook download, but will not support caller id name and number display. Surely not!!!!
Also to any current owners or plugnplay. What is the lcd on the units like in day driving with sunlight. Most of the cheaper chinese units seem to have very low quality highly reflective lcds that wash out almost completely
even in indirect sun. Not good in a car interior. I have seen a couple of units that use good lcd's that cope very well with the sun. Would be interested to know how the roadfly units perform in this regard.
cheers
Edited by wilsact
Hado,
Why did you add a microphone when there is already one installed in the light assembly in the roof between the driver and passenger?
Is it possible to connect the rear vision camera that currently exists in the KX-S to the 8" screen rather than the pitiful 3.5" screen?
How do you find the performance of the unit now that you've had it installed for a little while?
Would you do anything different?
Did you buy this online and if so from where?
Interested in your reply,
Whofan
All
Sorry for the very slow response on these questions - I have been very busy at work and haven't had time to log on.
You need to have the microphone close to your mouth or you get echo/feedback from the car speakers.
Yes - but it requires some minor electrical changes - cutting re soldering wires - not just plug and play - I was too keen to get it working. I don't think you need the large screen - and I am not sure it would work because there is a safety warning screen which might delay the picture feed - it usually delays the radio until after you have backed out.
I am very happy with it. My phone connects very time perfectly and the sound quality and features are a worthwhile upgrade. I use the iPod feature a lot and the GPS only when driving somewhere I don't normally go - just for the red light camera warnings etc.
Put the microphone further up the pillar/door rubber so it was a close as possible to my face when driving normally - I had to change this after the first install.
Easypark Australia
Kind regards
Hado
Hado, thanks for the reply, I was wondering if you were going to return to the forums, very glad you did.
Another follow-up question regarding the microphone if I may... You say that you installed it on the driver's A pillar as sound quality is better, less echo from the speakers. I've not had that reported to me yet from other people I've spoken to using the standard setup. So you have simply disconnected the mic located in the overhead light and fed another mic cable (presumably came with the purchase of your E7548NAVI?) to the A pillar location?
Regarding the GPS and maps... you mentioned in your original messages that it took some time to get these working, have you uploaded any updates since your original install?
All of the images I've seen (from FlyAudio China and US) show the volume knob on the left hand side as I guess it is being fitted to a US Highlander which is left-hand drive. Did you unit come with the volume knob on the left? Not that this is a "deal breaker" but I imagine it would be a little awkward for the driver to reach for this when ideally it should be closer to the steering wheel.
Edited by whofan
The mic which came with the Fly Audio unit just runs from the back of the unit under the dash, in between the to halves of the dash near the door and under the door rubber up the A pillar. I didn't have an existing mic - the original KX-S 6 CD unit used an inbuilt mic - which was why it didn't work very well. I never if checked to see if the Grande mic is in the overhead unit
The IGO8 software took a while to get working because you I needed to find the settings for the screen resolution and connection to the GPS receiver - I have posted this now. IGO8 is very customisable so some of the effort was getting the skins (look) I wanted to use working. You don't have to do this because the unit comes with software - but I wanted to use IGO8 because of its features and I had experience customising it already for a portable WinCE unit I owned. I learnt how to do this using other forums on GPS software. It's not that hard. All the changes are made to some simple code in a system file.
The skins are easy to find - here is the skin I am using. kikker skin
Yes it is on the left - but it is slightly bigger than the air temp knobs so easy to turn and not hard to reach. However, all the steering wheel controls also work - so you can change the volume on the steering wheel.
The volume control knob is much better than the original KX-S unit which was slippery and hard to grab and turn.
All
I just noticed some of he earlier questions I missed about the hazard switch and GPS software.
This post needs to read as well - it was where we worked out what to buy and how to solve some of the install problems etc.
Earlier parts and software post
Hope this fills in some of the blanks.
Kind regards
Hado
UPDATE ON FAULTY - Pay per view - Kluger GPS / DVD system
Hi Guys,
Well I am not happy at all as I sent the unit back to China weeks ago and have heard absolutely nothing. I've emailed them several times and I get absolutely no response, so I have a nice 2008 KLUGER with a huge hole in the centre dash.
Definitely do not buy the unit from Ebay under seller "pay-per-view". They did have a bit of negative feedback and I overlooked it because they sell a lot of stuff, but hopefully this will help my fellow Kluger owners from making the same mistake that I did. $650 GONE........ Now i need another one......to fill in the hole. I'm interested in the FLY unit but not willing to pay more than about $900.
Paul.
<br>UPDATE ON FAULTY - Pay per view - Kluger GPS / DVD system<br><br>Hi Guys,<br><br>Well I am not happy at all as I sent the unit back to China weeks ago and have heard absolutely nothing. I've emailed them several times and I get absolutely no response, so I have a nice 2008 KLUGER with a huge hole in the centre dash.<br><br>Definitely do not buy the unit from Ebay under seller "pay-per-view". They did have a bit of negative feedback and I overlooked it because they sell a lot of stuff, but hopefully this will help my fellow Kluger owners from making the same mistake that I did. $650 GONE........ Now i need another one......to fill in the hole. I'm interested in the FLY unit but not willing to pay more than about $900.<br><br>Paul.<br>
I am so sorry that you're in that situation, that has to be terrible, loss of cash and an ugly hole in your dash. Can't you refit the original radio to at least fill the gap and give you a better view whilst driving?
I've been constantly browsing ebay looking for Kluger accessories and seen the pay-per-view junk, thought of you and steered clear of it.
Have you considered notifying ebay of this shonky seller so they may intervene and make them accountable?
Thanks for your post, you've certainly made me wary of this dodgey seller, thanks also to the poster who mentioned how his tow ball was pinched... made me buy a hitch pin lock.... just goes to demonstrate the value of these forums.
I hope that your Chinese experience takes a good turn, they repair the unit and send it back with an apology!
Edited by whofan
Hi ,
Actually next month the new upgrade for this model will include Bluetooth phonebook
George
Any news on the new flyaudio unit, that was going to launch in April?
Cheers
Hi ,
George
Cheers
Hi ,
THE NEW MODEL WITH PHONE BOOK ,WINCE 6.0 , RDS IS NOW AVAILABLE
THANKS
George
Hi ,
George
Cheers
Hi ,
THANKS
George
Hi George,
Sent you a pm in regards to price and further details on unit.
Just checking if you got it?
Cheers
Thanks for all the great work guys.
Just picked up a new altitude & this looks the way to go.
Are all those who've already installed this - Hado, Ham ect still happy with these units in general & the following features in particular?
Bluetooth phone function.
Ipod interface
GPS
Cheers all.
Hi ,
George
Cheers
Hi ,
THANKS
George
Hi George,
Cheers
Hi ,
George
Cheers
Hi ,
THANKS
George
Hi George,
Cheers
Hi ,
Did you receive my Quote for this unit through PM Email ?
Regards
George
Hi ,
Yes this unit will fit your model Kluger
please contact me at sales@easyparkaustralia.com.au for more information
Regards
George
Hi George, I can't find the FlyAudio units for the Kluger on your website?
Hi ,
Regards
George
Let's hope that Easy Park are using the savings from their way-ordinary web site to reduce the price of their goods and services. That site looks like it's a primary school project! :huh:
Ipod interface
GPS
Cheers all.
Clawed
Bluetooth phone function - connects everytime and works fine - intially I had a problem with the sound quality and moved the mic closer to the driver - but in the end I found the mic supplied was faulty or I damaged it during install. I replaced it with a similar $20 mic from Jaycar and it now works very well. No one ever complains about the sound quality and I am told when they are talking it cuts out the background noise - which is better than most systems I have used in the past.
Ipod interface - this is my favourite part of the whole system - searchable by artist, album and song etc. I use this all the time - better than the radio - no ads and my music.
GPS - this depends on the navigation software you run - I am in the middle of testing the latest update of IGO8 and just updated to the latest R16 Australia map.
IGO8 has 3d buildings and shows major street signs ahead.
I use the more accurate speed indicator on the the GPS rather than the speedo on any highway trip.
Hope this helps.
Kind regards
Hado
Just a quick question Hado or George.
If you stop the engine with gps map on screen, but leave power running in acc position (like at a service station etc) what happens when you restart the engine. Does the unit/gps have to
completely reboot or is there a delay so you can just continue on with map still onscreen.
I have never tried this - I will give it a go and let you know
I know the GPS restarts remembering your destination when you turn the power off during a break in the trip etc.
Thanks mate. I know that some systems require a full reboot/startup, where others won't lose anything if you are just doing an engine restart and whats on screen stays on screen.
Same for instance if you had the radio or ipod screen up, pain if it reboots the whole unit just restarting engine.
regards
      Boot Dimensions?
    2. 1
      2007 - Floor mat
    3. 0
      2007 - floor mats
    4. 6
      Front parking sensors
      Cruise Control Not Engaging
    6. 0
      Head Unit with Apple CarPlay
    7. 4
    8. 1
      2007 - Floor mat
